Cannot figure out to remove the existing thermostat and replace.
May 27, 2014 at 3:30 AM
✓Experienced Mechanic
You have to go through the bottom of the inner fender well. (driver's side). Once there, you have to use an extension on the ratchet with a swivel end to access the inner housing bolts. Have you located the thermostat?
May 27, 2014 at 4:04 AM
JDL
You get at it through the left wheel housing. Safely raise and support the vehicle. Remove the tire and wheel housing liner.
Number 4 in the picture is the thermostat housing.
Image (Click to enlarge)
May 27, 2014 at 4:05 AM
JDL
Hi jacobandnickolas,
I didn't see you, have a good day.
