Transmission speed sensor replacement
150,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
ITEK4BUX
How do I locate and replace the transmission speed sensor on a '94 Ford Probe with Automatic Transmission?
Oct 11, 2018 at 7:59 AM
  • 110,251 POSTS
The vehicle speed sensor is located on the trans-axle below the air filter box. Here are the directions for replacement. The attached pictures correlate with these directions.
Procedures
Vehicle Power-train Management Sensors and Switches - Power-train Management Sensors and Switches - Computers and Control Systems Vehicle Speed Sensor Service and Repair Procedures
PROCEDURES
REMOVAL
1. Disconnect the battery ground cable.
NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the power-train control module relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the adaptive strategy.
2. Remove the engine air cleaner.
3. Disconnect the electrical connector from the Vehicle Speed Sensor (VSS).
4. Remove the VSS bolt.
5. Remove the vehicle speed sensor from the trans-axle.
INSTALLATION
1. Replace the O-ring.
2. Install the VSS bolt and tighten to 8-10 Nm (71-88 lb in).
3. Connect the electrical connector.
4. Install the engine air cleaner.
5. Connect the battery cable.
__________________________
I hope this helps. If you have other questions, let me know.
Oct 11, 2018 at 12:17 PM
ITEK4BUX
Thank you! This is exactly what I needed. Is the same part number used in both the 2.0/2.5L automatic and manual transmissions?
Oct 12, 2018 at 2:45 AM
  • 110,251 POSTS
Welcome back. From what I can tell, the automatics are the same. However, one for a manual transmission will be different.
Oct 12, 2018 at 9:13 AM
ITEK4BUX
Well, it sounded easy. Got the air cleaner removed, but cannot find the VSS under it.
Oct 13, 2018 at 4:40 AM
  • 110,251 POSTS
It is on the lower rear of the transmission. See if this picture helps you find it.
Oct 13, 2018 at 12:38 PM
