leaking around the high side port it need to be replace.
Aug 12, 2025 at 11:04 AM
✓Experienced Mechanic
Yes, this is easy to replace, I assume all of the refrigerant has leaked out correct? Here is how the job is done and I have included a video to help with the A/C vacuum down and recharge.
Check out the images (below). Let us know if you need anything else.
Image (Click to enlarge)
Aug 13, 2025 at 4:15 AM
JOE1953
MEMBER
the parts in the middle do it just screw out? I tried a 5/8 wrench but my wrench want to slip. this is valve core wrench I'm using trying to remove the core but nothing come out.
Aug 13, 2025 at 6:39 AM
Yes, it wont it is made as all one piece I would try vise grips to get the valve assembly out.
