How do I remove a cut open oil filter.
125,708 MILES
ROYCAR71
  • 359 POSTS
I tried using 2 separate oil wrenches and screw driver before going to this option . Currently, I have it soaking with bb blaster spray to lube good. Is there any way to remove the stuck oil filter after you cut it open?
Oct 5, 2013 at 5:22 AM
ROYCAR71
  • 359 POSTS
Here are pictures
Oct 5, 2013 at 6:20 AM
HMAC300
  • 48,601 POSTS
try taking a chisel or punch and hitting where you don't damage the oil filter housing to take off filter. then don't tighten it so damn tight then next time. Also use a better filter like Purolator, wix, bosch that have stronger cans and do a better job anyhow
Oct 5, 2013 at 6:56 AM
ROYCAR71
  • 359 POSTS
This walmart gaffer. Thinks.
Oct 5, 2013 at 7:04 AM
