Ford dealership says I need a heated PCV assy for my engine. It's the 5.4L V8 so the PCV connects from the back of the engine intake manifold at a 3/4" nipple down to the passenger side valve cover. However, there is an extra line coming off of that assembly. Ford-Parts.com shows a diagram of the hose going somewhere between the intake and throttle body but I can't make out where nor do I see ANY available ports at all for it to plug into. There are no coolant hose attachments as far as I can tell. Where does this extra hose go?
Mar 30, 2016 at 6:03 PM
