Codes p1472, p1425, and p0102, how do I get my car out of limp mode?
2000 VOLKSWAGEN BEETLE
158,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
KEN ANDERSON
I did code test p1472 p1425 p0102 now I have changed battery mass air flow sensor purge valve for EVAP checked all hoses and electrical connections everything seems good. All my fluids are topped off. I disconnected the battery for over 30 minutes and cleared all codes with the code reader still immediately picks the same codes right away in about 3 seconds.
Sep 24, 2023 at 3:10 PM
  • 55,423 POSTS
The diagnostic trouble codes (DTCs) you've provided are related to various issues in a 2000 Volkswagen Beetle.
P1472 - EVAP Leak Detection Pump, Insufficient Vacuum:
P1425 - Secondary Air Injection System, Bank 1:
P0102 - Mass or Volume Air Flow Circuit Low Input:
So, all of these codes can be caused by the catalytic converter is clogged. Please go over this guide to help confirm the issue:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Here is a video to help you change the cat out if it fails the test:
https://youtu.be/1Hh12_mWw8k?si=qcovtuSy-Yv-gUz0
Please let us know how it goes.
Sep 25, 2023 at 2:11 AM
