Codes p1895 and p1625, how do I get it out of limp mode to start again?
120,000 MILES • 6 CYL • AUTOMATIC
NAKEDN8V
Codes p1895 and p1625 are the main ones I'm worried about, I drove it home and the next day wouldn't start, and it doesn't crank over. lights and everything come on but it wont start and we need to move it because it's parked 2 blocks away on a cross street. They will tow it. Any advice please help?
Aug 17, 2022 at 1:17 PM
  • 55,710 POSTS
Codes p1895 is for a bad TCM and the p1625 code is for a bad throttle pedal sensor but I have seen if you clean the throttle bore this code might go away so you can get the car moved. Also, check all fuses, here are two guides to help us:
and
Check out the diagrams (below). Please let us know what happens. You can try clearing the codes as well.
Aug 18, 2022 at 4:03 AM
NAKEDN8V
Will removing the ECU fuse out for minute or two will that reset the codes or sensors that caused limp mode, possibly?
Aug 18, 2022 at 4:23 AM (Merged)
  • 55,710 POSTS
Yes, it should remove the fuse for at least 15 minutes, let me know what happens.
Aug 18, 2022 at 4:24 AM
NAKEDN8V
Ok was driving and al of a sudden screen says oil pressure too low turn engine off, it's done this a couple of times but I would turn it off wait a few mi ites and it would drive e normal again well like I said I was Sri king and the oil pressure shoes up again so I pull over turn engine off waited this time it was couple hours cause I fell asleep waiting anyways i was able to start it and drive it back home parked it and coue hours later it wouldn't start. Put o d scanner and codes p1895 and p1625 showed up, is this an easy fix I can do my self what do I have to do and is it in limp mode or faulty error code coming from the computer I dont know so any kind of input, sum advice to put me in the rite direction would be appreciated cause I dont no what to do and it still wont start anyways Thanks for istenu g to my problem and thanx for your time.
Aug 22, 2022 at 4:40 AM (Merged)
  • 55,710 POSTS
It sounds like you have an oil pressure issue, I would remove the oil pan and clean the oil pump pickup when can get clogged up with gunk. This is a common problem, please do not start a new question with the same problem, continue with this thread until resolved.
Aug 22, 2022 at 4:43 AM
