How do I fix this?
111,111 MILES • 4.0L • V8 • 2WD • AUTOMATIC
NIKO24K
Hollowed out the muffler now it won’t start.
Nov 29, 2022 at 4:47 AM
  • 110,248 POSTS
That doesn't make sense. If the muffler were to fall off, the engine would still run. What exactly was done to the muffler?
In most cases, a crank no start condition is caused by either a fuel issue or ignition spark issue.
Here is what I need you to do. Try using starting fluid to see if it starts. If it does and then stalls, we know there is a fuel-related issue. If there is absolutely no change, check for spark to the plugs.
Here is a link showing how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know exactly what was done to the exhaust and the results of the aforementioned test.
Nov 29, 2022 at 11:47 AM
