How do I drain and fill manual transmission fluid?
125,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
QUICKTECH
  • 13 POSTS
Can't find the manual transmission drain plug on my car listed above. Takes Dexron 3.
May 21, 2021 at 9:27 AM
It is a bit hidden and blends in with some of the other bolts. Below you will find the process from the manual that shows the drain plug location and the process for checking the fluid.
Basically you fill the unit until it comes out of the check/fill plug. Then you install this "check plug" and are finished.
Please let us know if you have other questions. Thanks
May 22, 2021 at 11:01 AM
