Box-shaped fuses/relays in the fuse box under the hood testing procedure
2004 SAAB 9-3
175,000 MILES • 2WD • AUTOMATIC
CERCOLANI
MEMBER
How do i check the box-shaped fuses/relays in the fuse box under the hood?
Thank you
Jun 10, 2020 at 4:29 AM
✓Experienced Mechanic
Take a look at these guides on how to test a relay and fuse. If this does not cover what you are looking at, send a picture of the specific ones you are talking about and we will come up with a way to check them out. Thanks
