Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mitsubishi
Galant
Steering
Pump
Replace/Remove
Power steering pump replacement
1996 MITSUBISHI GALANT
200,000 MILES • 2.4L • 4 CYL
TYLER FILLMORE
MEMBER
1 POST
How do I change the power steering pump? I cannot figure where the tension pulley is to loosen belt.
Oct 31, 2017 at 4:17 AM
PATENTED_REPAIR_PRO
Experienced Mechanic
On the power steering pump bracket, loosen the four bolts, two in front and two in the rear.
Here is a diagram:
Image (Click to enlarge)
Oct 31, 2017 at 6:03 AM
This guide will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Cheers, Ken
Nov 2, 2017 at 4:06 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
