Do I have to replace the thermostat when doing a coolant flush
97,034 MILES • 3.1L • V6 • 2WD • AUTOMATIC
BLAKE FALCON
Do I need to change my thermostat when I do a radiator/coolant flush? If so how do I take off my thermostat housing if the throttle body and intake manifold are in the way?
Apr 11, 2018 at 6:47 AM
STEVE W.
  • 15,418 POSTS
You do not have to change it but it is a good idea to do so while you already have the system drained. On the Corsica the exhaust crossover is over it and the throttle body is in the way as well. Normally I will remove the crossover pipe then use a bent wrench to remove the top bolt. If it was my vehicle I would remove the throttle body as well, that would enable you to clean the carbon and dirt out of it as well, plus gives you better access.
Apr 11, 2018 at 7:52 AM
