How do I change light bulb on gear shift
2003 TOYOTA CAMRY
190,000 MILES • 4 CYL • FWD • AUTOMATIC
RUTH POYNER
Light is burnt out on gear shift.
Apr 1, 2017 at 6:38 AM
HMAC300
  • 48,601 POSTS
see pictures. you will need a small screwdriver to pry the piece out to get to bulb. do not let spring and button go flying.
Apr 1, 2017 at 8:55 AM
LBROWN1982
  • 5 POSTS
I was backing my car out today and when I put it in drive the light around the D didnt light up, I was still able to drive the car fine though. Two weekends ago when I was backing out of the driveway my car turned off, but this was before I found out that I had a crack in my radiator and all my coolant had leaked out (this has since been fixed). Should I be worrying about a transmission problem or could this be something electrical? All the other gears (P, R, 2, N, L) light up when I shift to them. No check engine light or anything is on either
Nov 26, 2020 at 4:38 AM (Merged)
FISHERMAN
  • 937 POSTS
[quote:0b1bf2afab="lbrown1982"]Transmission problem
1998 Toyota Camry 4 cyl Front Wheel Drive Automatic 195880 miles
I was backing my car out today and when I put it in drive the light around the D didnt light up, I was still able to drive the car fine though. Two weekends ago when I was backing out of the driveway my car turned off, but this was before I found out that I had a crack in my radiator and all my coolant had leaked out (this has since been fixed). Should I be worrying about a transmission problem or could this be something electrical? All the other gears (P, R, 2, N, L) light up when I shift to them. No check engine light or anything is on either[/quote:0b1bf2afab]
Nothing to worry about, looks like the light indicator its burn, just needs to be replace.
the one on the dashboard or in the shifter?
good luck!
LBROWN1982
  • 5 POSTS
The problem is in the dash board, how would I get that off and if I go to a mechanic about how much do you think it would cost me?
