how do I bypass thermostat?
35,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
MIKE HABERMAS
I need to bypass the thermostat to use blue devil gasket sealer. To try an fix head gasket leak. As per the the instructions. What is the best way to do this? I was going to use pvc and connect the hoses that way, but it I'm thinking there must be a better way.
Oct 26, 2020 at 5:38 AM
  • 110,248 POSTS
It can't be bypassed simply because it is attached directly to the radiator. What I would suggest is to remove the thermostat when performing the procedure. Once you finish and everything is finished, reinstall the thermostat.
Here are directions for removal and replacement. The attached pics correlate with the directions.
____________________________________________
2015 Chevrolet Cruze L4-1.8L
Engine Coolant Thermostat Replacement
Vehicle Engine, Cooling and Exhaust Cooling System Thermostat Service and Repair Removal and Replacement Engine Coolant Thermostat Replacement
ENGINE COOLANT THERMOSTAT REPLACEMENT
Document ID: 3755076
Removal Procedure
Engine Coolant Thermostat Housing Replacement Remove
Note, coolant must be drained to a level below the thermostat. Otherwise, it will leak from that point.
Bolt (1) total 4 Remove
pic 1
Remove the thermostat. (2)
Engine Coolant Thermostat Gasket (3) Remove and DISCARD
Installation Procedure
Install a NEW gasket. (3)
pic 2
Install the thermostat. (2)
Engine Coolant Thermostat Housing Replacement Install
Oct 26, 2020 at 6:14 AM
STEVE W.
  • 15,411 POSTS
On that car I would be very tempted to buy a cheap aftermarket thermostat and gut it by pressing the ears down and removing the capsule and valves discs for that use. That would allow the sealer to flow easily and then once you are finished replace it with the one on it or a new OEM unit if it seems the sealer worked. How bad is the leak you have? Blue Devil does work on smaller leaks but I consider it a band-aide repair myself.
FYI the ingredient in Blue Devil that does the sealing is sodium silicate AKA water glass, this is also the chemical that they used in the cash for clunkers program in 2009. For that they drained out the oil, dumped in a gallon of water glass solution and started the engine. As soon as the engine got warm the solution would cause the engine to grind itself until it locked up. Although they claim that theirs won't cause a problem I would only run the engine long enough to get it warm, then I would change the oil.
Oct 26, 2020 at 11:05 AM
