How can identify if the leak is from the crankshaft seal or gear box without taking it out?
JNEILSON10
MEMBER
2007 FIAT PUNTO
TURBO
MANUAL
96,000 MILES
Mechanic has said that there is a leak either coming from the crankshaft seal or gearbox, but wont know until they pull it out, which is going to cost a lot.
I need it to pass MOT as I need it for work. Any way to know without pulling it all out and can I do a simple fix for now until I have the finances to fix it properly?
SPONSORED LINKS
Sunday, June 6th, 2021 AT 3:26 AM
MECHANIC
Good morning,
I would clean the area very carefully of all oil residue. Then I would go to a parts store and get a tube of oil dye. Add it to the oil and run the engine for about 2 hours.
If it is the rear main, you will see the dye in the oil leaking on the ground. There is no quick fix for that. It is a big job to replace that seal. The seal will need to be replaced and the rear main bearing will have to be replaced or at least checked. The main reason for the seal leak is from the shaft wobbling from wear.
