Started running hot then it shut off
2005 JEEP GRAND CHEROKEE LAREDO
114,538 MILES • 3.7L • V6 • AUTOMATIC
SHANTRELLE SMOOTH LMT
Six months ago i got this vehicle. Four days after i had it six months it runs hot and shut off. Was told i needed a water pump. Got it replaced but did not help. They broke it apart because warranty said so . Engine is cracked, head is broken. The entire time i had the vehicle only issue was needing to replace coolant. No signs of leaking other than needing to refill. now i still have most of the time to pay it off and my not so great warranty will not cover repair telling me vehicle has overheated many times. I need help and my vehicle fixed.
Dec 6, 2016 at 2:38 PM
HMAC300
  • 48,601 POSTS
if head cracked and you kept filling coolant then it was probably a head gasket leak and it got worse. so not the head will need replacing as well as head gaskets.
Dec 6, 2016 at 11:08 PM
whole engine needs to be replaced. when i told them i had to refill coolant, i was told that is normal.
Dec 7, 2016 at 2:09 AM
HMAC300
  • 48,601 POSTS
if you have to add fluid all the time it is leaking somewhere.
Dec 7, 2016 at 4:00 AM
