license plate bulb replacement
100,000 MILES
KABUKI
One number plate bulb is not working i have try to open the lamp by screwdriver i put the screwdriver in to the small hole from under plate number and i pull it up. but is not working because if i try to pull hard i m afraid i m going to brake the lamp.
Sep 11, 2013 at 1:27 AM
Good afternoon,
That part is sold as an assembly which means the bulb and the housing are all 1 unit. You will need a dealer to get the part and then unbolt the housing and disconnect the wiring. then install the new unit on the car.
Apr 3, 2020 at 6:21 AM
