how can i get my car to run as best as possible
2001 CHEVROLET BLAZER
84,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
FG0803
my truck is leaking oil from the rear and front crankshaft seal due to vibration from a vacuum leak i belief. i fixed the vacuum leak, but since i will be repairing it myself and will have everything apart i want make sure i check everything possible that i can,maybe even improve it, with performance parts if possible or just some pointers of the vehicle i should check. how can i get my car to run as best as possible.what are some major compartments to go over and check. how can i increase the power
May 1, 2019 at 7:00 PM
  • 55,423 POSTS
The best way to go is to leave it stock and use AC Delco parts, did you want to fix the oil leak or? IF so here are two guides to help walk you through the repair and give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/front-main-seal-replacement
and
https://www.2carpros.com/articles/crankshaft-main-seal-replacement-rear
May 3, 2019 at 6:02 AM
