2002 Chevy Blazer Relearn Crankshaft Sensor
2002 CHEVROLET BLAZER
93,000 MILES • 6 CYL • 4WD • AUTOMATIC
PIONEERLOGS
How do you perform a relearn on a crankshaft sensor. Is this expensive if you take it to a dealer?
Apr 2, 2008 at 10:34 PM
RHALL77
  • 3,361 POSTS
you will need a tech 2 to do it. where i live they charge an hours worth of labor for the job, but it only takes 45 sec to perform if the car is warmed up.
Apr 3, 2008 at 12:26 AM
PIONEERLOGS
Would it help if I returned the 'aftermarket' crankshaft sensor and bought a new GM sensor for this vehicle. I heard sometimes you can do this and it does not have to be set up 'learned'?
Apr 3, 2008 at 1:41 PM
RHALL77
  • 3,361 POSTS
not sure on that, may i ask why do you think you need to do a crankshaft relearn. the only time you should have to do it is when you reprogram the pcm.
Apr 4, 2008 at 12:06 AM
