timing belt tension-er broke
155 MILES
BOOBSVINCEN
Timing belt tension-er it broke small piece on the back is okay to use it like that?
Apr 7, 2018 at 10:36 PM
Good morning.
No it is not. the bad tension-er will alter engine timing and could cause engine damage as this is an interference motor.
it is number three in the picture.
To access, you need to remove the cover for the timing belt. in your car, it is a difficult procedure if you have never done it before. Are you planning on performing this repair yourself?
Apr 7, 2018 at 11:44 PM
