So the temperature sensor feeds information to the PCM which turns the fans on, so are the fans not working? What makes you say the sensor is not working, did you get a trouble code?
Jul 23, 2025 at 2:57 AM
LIBERSTY
MEMBER
No I test sensor with multimeter, and it gives 2.63 cold water and 0.31 hot.
Jul 23, 2025 at 6:17 AM
✓Experienced Mechanic
The sensor is working properly based on resistance readings.
