Hot fuel tank and disappeared oil
2000 VOLKSWAGEN EUROVAN
8,200 MILES
NEEDLE
Got off freeway after traveling 65mlhr for 15 miles. Cabin floor over fuel tank felt hot, I opened fueling cap and it hissed, heat came out and I could see gasoline bubbling. Waited for Van to cool off a bit and checked oil (had oil changed and fluids topped off 6 weeks ago) there was no oil on the stick! What's going on?
Aug 30, 2013 at 1:11 PM
EXOVCDS
  • 1,883 POSTS
Check for fault codes in the ECM.
Check for any signs of running too hot or too rich.
Also check the exhaust / catalytic converter for restrictions.
Pull the plugs and check which cylinders are burning oil... usually #1 and #6
but I had a golf in not too long ago that burnt oil in all cylinders.
Thomas
Aug 30, 2013 at 3:38 PM
  • 31,937 POSTS
Check for ash deposits on the spark plugs, this will be an indication that the cylinder is burning oil, are there any external leaks?
Sep 3, 2013 at 10:09 PM
