Engine running hot
85,000 MILES • 3.0L • 2WD • AUTOMATIC
DONA MCGEE
Engine light came on. AutoZone read, thermostat need replacing. Husband replaced. Now car tends to run hot. Have plenty of coolant
Oct 30, 2020 at 9:35 AM
Couple things first. If the engine runs hot, what does that mean? Can you get a picture of the gauge where it shows where it is running hot? Then do you know what thermostat he installed? They have different temperature thermostats so he may have put one in that opens at a higher temperature.
Let's start with this and go from there. Thanks
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Oct 30, 2020 at 9:59 AM
