Hot air passenger side when a/c is on
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BEACHYD
Can you tell me which actuator/s need changed to effectively correct my problem? I'm hoping it's not the passenger actuator on the top and right under the duct work.... Please help!
Jun 13, 2014 at 9:59 AM
  • 110,251 POSTS
That is the blend air door actuator. Yes, it's under the dash near the heater core. Not an easy one to replace.
Jun 13, 2014 at 1:13 PM
BEACHYD
Should I go at it from the top, cut the duct right of center, or from underneath?
Either way, where can I find an exploded view of the dash assembly?
Jun 13, 2014 at 1:43 PM
  • 110,251 POSTS
I don't have a schematic for you... sorry. As far as access, it should be under the dash on the passenger side.
Jun 17, 2014 at 1:34 PM
