The A/C is blowing out hot air more than cold?
200,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CHARLENE SMALLWOOD
The Compressor is kicking on and does not need Freon. Ready to blow up car!!! Any help appreciated.
Aug 25, 2023 at 7:42 AM
  • 55,766 POSTS
I would turn the system on and then confirm the larger A/C line-tube coming from the fire wall is cold, if so, the air mix door actuator needs to be replaced. Here is a guide to go over and the location of the actuator in the images below:
Check out the images (below). Please let us know what happens. Follow the red arrow to show you the place to grasp for the temperature check.
Aug 26, 2023 at 5:42 AM
