A/C blows warm air when driving
74,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CADZAN
The cars air conditioner, will blow fairly cold air, upon start. But while driving, it blows warm. Coming to a stop, it will cool off some.
Jul 14, 2018 at 6:44 AM
  • 110,248 POSTS
This could be the result of low Freon in the system, a partially plugged system, a blend air door in the vehicle not functioning properly.
Since it never gets more than "cool" before driving, I would start by checking both the high and low side compressor pressures. Here is a link that describes how the system is properly recharged and discusses pressures from both sides of the compressor:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Once you determine the pressures, let me know the following. What both the low and high side pressures are and I will need to know the outside temperature when tested. Ambient temperatures (outside temperature) will play a big role in what the pressure should be under different conditions.
Do this first and let me know what you find.
Thanks,
Jul 15, 2018 at 1:28 PM
