When engine gets hot the A/C does not work
162,062 MILES
BLKMOON
My AC does not work when my car gets hot.
Apr 29, 2018 at 11:01 AM
Good morning.
When your car gets too hot from a cooling system issue, the AC will not work. The condenser will not get proper cooling from the air flow and the AC system will not work correctly.
Is the car overheating?
Apr 29, 2018 at 9:22 PM
BLKMOON
No the car is not overheating. When the is pack and it gets cool the A/C comes on.
Apr 29, 2018 at 9:34 PM
Do you have a set of AC gauges that can read the high and low pressures? It would be good to see the pressures when the system gets hot.
Apr 29, 2018 at 9:38 PM
BLKMOON
No I do not have one.
Apr 29, 2018 at 9:39 PM
You can rent a set of buy a cheap set for about $30.00 from Harbor Freight.
Unfortunately without seeing the pressures, it is difficult to help you get an answer.
Apr 29, 2018 at 9:44 PM
BLKMOON
Thank you very much. My cooling fan will not come on either.
Apr 30, 2018 at 4:20 AM
BLKMOON
Thank you very much. I will do that. You been very helpful.
Apr 30, 2018 at 5:54 AM
You are welcome.
Apr 30, 2018 at 5:56 AM
