Horn does not work?
2001 FORD F-150
82,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
RICHARD.ROBINSON
The horn will not work. I have already replaced the clock spring and tried another horn the other horn did the exact same thing, something else?
May 19, 2018 at 12:05 PM
SQM
  • 6,383 POSTS
Have you checked the horn relay?
It could be a faulty relay that causing to have no horn.
The relay is located under the hood fuse block. I have attached the diagram for your reference.
Here is a helpful article on how to test relays:
It could also be a short somewhere in the horn wiring harness. I included the wiring diagram for the horn as well.
Aug 1, 2021 at 6:55 AM
