Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Tempo
Safety
Horn
Relay
Location
Horn relay location
1992 FORD TEMPO
155,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
KATIE FELDMANN
MEMBER
1 POST
Horn not working.
Nov 2, 2016 at 10:03 AM
Experienced Mechanic
Check fuse and relay first, then if they are okay check that he horn works with external power applied and if that is okay, the problem will probably be in the horn pad switch.
Nov 2, 2016 at 8:18 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
