How to access the horn relay?
171,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TREEGUY1994
  • 5 POSTS
I know the horn relay is located on the convenience center on the passenger side. I am just having trouble finding it. How do I get to it?
Jul 11, 2024 at 8:56 AM
STEVE W.
  • 15,418 POSTS
It is inside the convenience center not on it. You need to remove the convenience center and then you can open it to replace the relay.
Jul 11, 2024 at 10:47 AM
TREEGUY1994
  • 5 POSTS
How do I get inside the convenience center?
Jul 11, 2024 at 11:46 AM
TREEGUY1994
  • 5 POSTS
Or removed the convenience center.
Jul 11, 2024 at 11:49 AM
STEVE W.
  • 15,418 POSTS
Remove the bolt that holds it to the dash and rotate it, you should see clips on the cover. Release them and the relay is inside. On others you just spin it around and the relay will be the 3 terminal one.
Jul 11, 2024 at 12:27 PM
TREEGUY1994
  • 5 POSTS
That’s the thing I can’t even locate the piece. Do I have to take anything off to get to it?
Jul 12, 2024 at 6:37 AM
STEVE W.
  • 15,418 POSTS
It is behind the trim panel in the passengers footwell.
Jul 12, 2024 at 1:15 PM
