Horn relay location
180,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
STU710
  • 6 POSTS
Cannot find the horn relay for my van. I found the fuse. The car horn is not working.
Jan 14, 2017 at 12:30 AM
STU710
  • 6 POSTS
It is a Touring Edition.
Jan 14, 2017 at 1:27 AM
HMAC300
  • 48,601 POSTS
see picture for where it is. however, it may be inside the module and not replaceable and needing a scan for codes by a mechanic. check wire leading to horns either with a test light or volt meter for power.
See the guides below for using a voltmeter and test light, also for testing wiring
Wiring diagram is attached below
Jan 14, 2017 at 1:41 AM
STU710
  • 6 POSTS
That would explain why I can't find it. Thanks.
Jan 14, 2017 at 11:34 PM
STU710
  • 6 POSTS
Got the horns off and back traced the wiring and it goes to the Fuse Box. Can't find the relay still
Jan 15, 2017 at 1:02 AM
HMAC300
  • 48,601 POSTS
reread my reply if it's in the module you will never find it as it's an encased relay
Jan 15, 2017 at 1:12 AM
STU710
  • 6 POSTS
Gotcha. Thanks.
Jan 15, 2017 at 2:17 AM
STU710
  • 6 POSTS
I'll try testing the wires to the horn to see if they get voltage. Thanks again
Jan 15, 2017 at 2:19 AM
HONDAHORN
horn starting blowing on its own, then blew #47 fuse. Replaced fuse but when I try to blown horn, fuse blows again. What is the cause and the fix?
Nov 21, 2018 at 8:46 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Check the horn and its relay.
DOROTHY49
The horn goes off when it rains.
  • 75,988 POSTS
Check the horn wiring connector and the horn relay
