Horn not working
62,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
ROCCO DAGGS
  • 12 POSTS
There are two horns on this car. I replaced the fuse and still nothing at all. I plan on jumping a wire from the battery to the wiring terminal tomorrow, but I was just curious it could be something that is common?
May 13, 2016 at 9:08 AM
CARADIODOC
  • 34,403 POSTS
Yes. Something that is very common. Get out your wallet. The insane engineers have seen fit to go way beyond hanging an unnecessary computer onto every part of our cars. We used to have a horn switch that turned on a ten-dollar relay that sent current to a pair of horns. On your car, the horn switch sends a specific voltage to the most complicated computer on the car, the instrument cluster. The instrument cluster interprets that as "horn request" and sends a digital signal to the "FEM", Front Electronic Module, which sends current to the horns. The most common cause of a dead horn is the instrument cluster, $850.00. The second most common cause is the FEM. Not sure of the cost of that one. Years ago the most common cause was one shorted horn and a blown fuse, but those days are gone. My fingers are crossed that it is something less-serious on your car.
The best place to start is to use a scanner to see what the instrument cluster is seeing. If there is no indication the horn switch is being pressed, you might suspect the clock spring is coming apart, especially if there is a second symptom of "Air Bag " warning light is on or something else in the steering wheel doesn't work. The clock spring is a wound-up ribbon cable in a plastic housing under the steering wheel. Once the cable starts to come apart, multiple circuits will stop working.
May 13, 2016 at 9:22 AM
ROCCO DAGGS
  • 12 POSTS
Thanks. It is my wife's car, she likes them big boats, too many electrical parts. The upside is it only has 62,000 miles mint condition for a 2002. I will get her an air horn she can stick out the window before I pay $850.00. We only paid $3,500.00 for the car from a friend. Thanks for all your help I appreciate it.
May 13, 2016 at 9:26 AM
CARADIODOC
  • 34,403 POSTS
If it comes to that I can help with wiring in a common sense relay, but you will have to figure out what you like for a switch.
May 13, 2016 at 9:37 AM
ROCCO DAGGS
  • 12 POSTS
I guess you are talking about hard wiring may be from the battery to the horn and to a switch somewhere on the dash?
May 13, 2016 at 9:39 AM
CARADIODOC
  • 34,403 POSTS
Yes. The circuit is pretty simple and can be copied from almost any older car brand and model.
May 13, 2016 at 9:47 AM
ROCCO DAGGS
  • 12 POSTS
I appreciate any easier way and cheaper way to give her horn. Figures any possibility of something inside the steering wheel I may have to remove and check the
connection.
May 13, 2016 at 9:49 AM
CARADIODOC
  • 34,403 POSTS
You really cannot check the ribbon cable unless you take the assembly apart. It is much faster to view "Inputs and Outputs" on a scanner. You might check at some local auto parts stores that rent or borrow tools to see if they have one you can use.
May 13, 2016 at 10:27 AM
ROCCO DAGGS
  • 12 POSTS
Okay, thank you.
May 13, 2016 at 10:31 AM
