Horn location
56,000 MILES • 3.2L • 4 CYL • 2WD • AUTOMATIC
KEN ROCHESTER
Horn fuse and relay okay. horn does not work.
Apr 8, 2019 at 11:43 PM
Good afternoon,
The horn or horns if you have more than one are behind the headlights and down.
I posted the procedure and some pictures for you to view.
Horn Replacement
Removal Procedure
1. Remove the right and/or left headlamp.
2. Disconnect the horn electrical connector.
3. Remove the horn bracket bolt.
4. Remove the horn from the front bumper impact bar.
Apr 9, 2019 at 1:02 AM
