Horn isn't working and airbag code?
160,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
RLPETERSON
  • 5 POSTS
Hello, I just got my truck running after a few months and my horn doesn't work and I have an airbag code B0022. What can I do to fix them both?
Dec 3, 2025 at 8:11 AM
  • 55,673 POSTS
We only handle one problem at a time, please start a new question for the B0022 code, we will handle the horn problem on this thread. I would first check the horn fuse which is under the hood as the "horn" fuse 15 amp, if that is okay I would swap out the horn relay which is in the same fuse panel under the hood. If those are good there is a horn ground G108 which is at the left radiator support bracket. This guide can help
Please go over this guide and get back to us.
Dec 4, 2025 at 12:47 AM
RLPETERSON
  • 5 POSTS
I found out the relay for the horn was missing. I replace it and now the horn works.
Dec 6, 2025 at 3:50 AM
  • 55,673 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Dec 7, 2025 at 2:21 AM
