Horn not working
100,000 MILES • 2WD • AUTOMATIC
YMCDANIEL
  • 5 POSTS
Hi guys!
I have looked and looked online and can't find which fuse goes to the horn. I can find the number for the one under the hood, but I need the number of the one located in the fuse box inside under the steering wheel. I know it's a 20 amp but can't tell which one it is. The horn is not working, and I want to check the fuse first.
Thanks, Yvonne
Jan 10, 2022 at 9:05 AM
  • 110,248 POSTS
It's fuse number 27 in the SC panel, left side of the dash. Now, I attached the wiring schematic below for the horn circuit. There are a few things that can cause it to fail, a clock spring, steering wheel control module, and so on. Here is what I need you to do.
First, check fuse 27 in the vehicle. It is a 1-amp fuse, so make sure you check it closely. In addition to checking the fuse, confirm there is power to it. Here is a link you may find helpful:
If you find that both fuses are good, you should have the can-bus scanned to see if there are codes related to the issue. CAN stands for controller area network. Basically, all modules are tied together via a few wires and communicated with each other. This type of scan will retrieve codes regardless of the module storing them. Here is a link that shows how it's done.
Let me know if this helps. Also, let me know if you have other questions.
Jan 10, 2022 at 12:22 PM
YMCDANIEL
  • 5 POSTS
Thank you so much!!!!! You are awesome!
Jan 11, 2022 at 6:40 AM
  • 110,248 POSTS
You are very welcome. I hope it helped.
Please feel free to come back anytime in the future. You are always welcome here.
Jan 11, 2022 at 11:33 AM
