Horn is not working
2008 ACURA TSX
210,001 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROBERT S. JACKSON
Having problem will not work. checked fuse and relay and horn not getting power.
Mar 23, 2019 at 5:58 AM
JOETECHPRO
  • 705 POSTS
Hey ROBERT S. JACKSON,
Just to confirm you have checked power and ground at both horns when operated with a test light/multi-meter?
If you have checked these the next step i would advise is checking for power input from the horn switch at the relay.
Let me know if you have access to a test light/multi-meter and what you have checked and i will let you know where to go next.
Regards, Joe
Mar 23, 2019 at 11:46 AM
