Horn blows when sitting still
97,727 MILES
ANTHONY43
The horn will blow after sitting for about an hour on its on. How can I fix that problem? Or what is the problem?
Sep 29, 2016 at 2:42 AM
JIS001
  • 3,412 POSTS
You would need to check for a short in the wiring between the steering wheel and horn relay. Since the ground wire starts from behind the air bag I strongly recommend you take it into a shop for proper diagnostic. What you can do for now is remove fuse number thirteen to keep the horn from coming on.
Sep 29, 2016 at 3:33 AM
ANTHONY43
The automatic truck light was flashing, would the make the horn blow? What about the alarm on it would that have something to do with it?
Sep 29, 2016 at 4:04 AM
JIS001
  • 3,412 POSTS
Is it your alarm that is setting off or is it the horn staying constantly on?
Sep 29, 2016 at 4:55 AM
