replacing steering wheel?
170,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
ACICERO
I got a new steering wheel but I don't know how to install it?
Apr 4, 2019 at 4:58 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is the information you requested. Here is a tutorial showing how to replace a steering wheel:
https://www.2carpros.com/articles/steering-wheel-removal
I've attached picture steps below showing how to remove and replace the steering wheel on your F-150. Hope this helps and thanks for using 2CarPros.
Jul 2, 2021 at 8:49 PM
Good morning,
I attached the procedure with some pictures for the repair. You will need a puller to release the wheel after removing the attaching nut.
If you have steering wheel switches, when you release the cover, there will be a wire connector there to release.
Jul 2, 2021 at 8:59 PM
