Horn blasting
80,000 MILES
DENNISLEROY
Can't find fuse to shut horn off
Jan 29, 2016 at 9:10 PM
WRENCHTECH
  • 20,760 POSTS
The horn shares a circuit breaker with other functions so you can't go that route. There is a horn relay in the engine compartment relay box. Removing that is the best way to disable the horns.
Jan 29, 2016 at 10:06 PM
WRENCHTECH
  • 20,760 POSTS
Hi HMAC300,
Unplugging the horns will leave the relay active and kill the battery. The relay should be removed.
Jan 29, 2016 at 10:11 PM
CADDYMAN2525
Noises problem
1998 Cadillac Deville V8 Front Wheel Drive Automatic
My horn in my cadillac deville is not working and dont know how to go about it can you help me?
Nov 16, 2019 at 5:32 AM (Merged)
FACTORYJACK
  • 4,159 POSTS
A little description of the circuit. The horns recieve power from the power seats circuit breaker, and that supplies power to both the control side and the switched side of the horn relay. The relay is controlled by grounding either from the horn switch, or the PZM(body control module) for theft or personalization requests. First check would be if the power seats work, that would validate the circuit breaker is functional. The horn relay is in the underhood fuse box. Check when the horns are activated, if the relay clicks. You can also swap it with another relay. It could be functioning(controlled) but still have a faulty switch contact inside. If it is clicking, check for power and ground at at least one horn connector. You could have two faulty horn assemblies. If the relay does not click when activated, you will have to track down the circuit that grounds it. Maybe even arm the theft system with a window open, reach in and manually unlock and open a door. If the lights flash and the horn sounds, you may have a problem with the horn switch, contact ring in the column, or a poor connection in the column under the airbag.
