When I turn my ignition off the horn blares and wont stop
187,235 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
BIGREDHUNTER18
When i turn my ignition off the horn blares and wont stop until the key is turned back on or I unhook the battery. I changed relay and fuse.
Sep 28, 2016 at 10:01 AM
HMAC300
  • 48,601 POSTS
have a mechanic scan for codes and check clock spring in steering column.
Sep 28, 2016 at 11:20 PM
BIGREDHUNTER18
Checked codes nothing showed and clock spring was check unhooked battery over night it has quit for now, but it started when i hit the panic button on my tudra.
Sep 29, 2016 at 12:24 AM
HMAC300
  • 48,601 POSTS
if you went to an auto parts nothing will show as they cannot read that module or used one similar to that if you remove the relay it should not work. It may be a security module problem so have a mechanic do it if not already.
Sep 29, 2016 at 2:45 AM
