Horn and radio control on steering not working
94,987 MILES
ASMUKTAR
Hello. I need help in finding why my horn and radio controls on my steering are not working. I went to an electrician and he fixed it for just a day. when i turn the steering it works but not anymore. it has stopped completely now. Please help
Apr 30, 2013 at 8:19 AM
KHLOW2008
  • 41,812 POSTS
What was done to fix the problem?
Is vehicle equipped with SRS and if yes, is the indicator light showing?
Problem is most likely be due to a fault with the contacts/connections under the steering wheel.
Apr 30, 2013 at 9:54 AM
ASMUKTAR
yes the srs sign doesnt go off too. and the EPS sign only blinks for a while when ever i start the car and then stays on. i think the electrician tried fixing the contact because i remember he said something like that, something flex. what do i need to change so that i can just buy it and fix it myself? thank you
Apr 30, 2013 at 5:23 PM
KHLOW2008
  • 41,812 POSTS
You need to replace the cable reel under the steering wheel. It requires the steering wheel and air bag to be removed. Care must be taken while installing the cable reel and correct procedures must be followed otherwise the cable reel wold be damaged.
The EPS could be something else, it is for the Electronic Power Steering system and you would need a scn tool to retrieve the trouble code to find out what is wrong.
Apr 30, 2013 at 9:09 PM
ASMUKTAR
will check that. for the eps i would find a technician then. thank you. can you refer mr to a website that i can buy the cable reel please. great pleasure.
May 1, 2013 at 6:26 AM
KHLOW2008
  • 41,812 POSTS
Sorry I do not have any website to recommend. Try gooling the part, you should be able to locate them easily.
May 1, 2013 at 11:20 PM
