Where is the horn fuse located?
191,393 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
ANDRUMBABEAT
Need to locate the horn fuse.
Oct 8, 2024 at 12:48 AM
ANDRUMBABEAT
Need to disable it.
Oct 8, 2024 at 1:51 AM
STEVE W.
  • 15,404 POSTS
That vehicle doesn't have an individual fuse for the horns. The horn gets power directly through the TIPM. The earliest build dates do have a removable horn relay, but that was relocated to the circuit board in the later build dates to make it non-replaceable.
The only other option would be to go to the horn sounder and unplug it to stop the horn.
Might I ask why you want to disable it?
Oct 8, 2024 at 2:13 AM
