Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Safety
Horn
Stuck On
While driving the horn goes off on its own
2003 DODGE CARAVAN
133,000 MILES • 3.3L • 2WD • AUTOMATIC
NICOLE LING
MEMBER
My horn starts to go off on its own when I am driving.
Mar 21, 2018 at 11:21 AM
Experienced Mechanic
Good morning.
Two things come to mind.
The horn pad is too sensitive and keeps the horn blowing
The alarm system is going off while you are driving.
Do the lights flash while the horn is going off?
Mar 21, 2018 at 5:18 PM
NICOLE LING
MEMBER
No.
Mar 22, 2018 at 3:49 AM
Okay, then most likely the horn pad is causing the issue. you can just replace the horn pad by itself.
Mar 22, 2018 at 5:14 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
