Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Fusion
Safety
Horn
Weak horn and alarm
2012 FORD FUSION
75,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
LAXDAD
MEMBER
1 POST
Horn and alarm horn working but very weak.
Jan 26, 2020 at 4:52 AM
Experienced Mechanic
Good afternoon,
Check the voltage to the horn. You will need to access the horns, disconnect the wires at the connector and have someone push and hold the horn button on. You should have battery voltage. It should be 12.3 or better volts.
Images (Click to enlarge)
Jan 26, 2020 at 5:26 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
