Does not start
170,000 MILES • 2.5L • 2WD • MANUAL
JIM38CURL
Hi. My Hiace ended the previously day faultlessly but when trying to start the next day it tries to start but slowly shuts off as though the batteries are flat. I put it down to needing new batteries but then noticed a little color disc that indicated that the batteries are fine. I connected some jump leads and without even starting my other vehicle and the Hiace started first time.
I know literally nothing about cars but I really think it is a battery problem but am confused by the indicator saying they are good.
Any pointers would be really appreciated before I go and spend the best part of £200 on batteries I may not need.
Thanks.
Jim.
Jun 10, 2018 at 5:34 AM
  • 110,248 POSTS
Hi Jim and thanks for using 2CarPros.com.
I have to be honest, this model Toyota is not offered in the US, so my specific knowledge is somewhat limited. Based on what you described, it sounds like you have a hybrid. If so, there is a battery which runs an electric motor and one that starts the car. What I would do is check the battery which is to start the vehicle. Here are general directions for checking a battery under a load. Do this first.
Let me know what you find.
Jun 10, 2018 at 12:19 PM
