Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Computer
Diagnostic Connector ALDL
hooking up OBD 1?
1991 FORD F-150
120,000 MILES • 4.9L • 6 CYL • 2WD • AUTOMATIC
AHKALISH
MEMBER
1 POST
Do you need to have a wire between the OBD1 and the battery?
Jul 7, 2023 at 2:28 AM
MATHGEN
Experienced Mechanic
No, you shouldn't have any need for separate wiring to the OBD test connector.
Are you using a scanner?
Here is a guide for retrieving codes without a code reader:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
I hope this helps.
Jul 7, 2023 at 4:19 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
