hooking up OBD 1?
120,000 MILES • 4.9L • 6 CYL • 2WD • AUTOMATIC
AHKALISH
Do you need to have a wire between the OBD1 and the battery?
Jul 7, 2023 at 2:28 AM
MATHGEN
  • 128 POSTS
No, you shouldn't have any need for separate wiring to the OBD test connector.
Are you using a scanner?
Here is a guide for retrieving codes without a code reader:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
I hope this helps.
Jul 7, 2023 at 4:19 AM
