Replacing hood struts?
24,000 MILES
TURNER122
I need to replace struts. They won't hold the hood open; how do you remove the old struts?
Jan 31, 2024 at 12:46 AM
  • 110,248 POSTS
I attached the directions below for the removal of the support strut. Installation is the reverse of removal.
When you do this, realize that once it is removed, the hood will instantly fall closed, so support it and protect your hands, fingers, and anything that can be hit by the hood.
Let me know if this helps.
Jan 31, 2024 at 5:35 AM
