I was on a road trip in Colorado. The hood release cable broke. I got a temporary fix by a mechanic who fixed up a piece of wire to pull on that would open the hood. This he fixed to a ring that could sit by the windshield wiper. Fine. The hood release cable lever at this point was just loose, unconnected to any cable.
I had to get the car looked at in Arizona but forgot to mention that to open the hood, they would have to pull the wire. I guess they tried at first to pull the lever under the dash, and then worked out about the wire.
Anyway, some time later i noticed that the hood release lever was jammed. It wouldn't move at all. It seems to be down, rather than up when it used to work before the cable broke.
I have tried (gently) to wiggle it to see if i could dislodge it from wherever it was jammed, but it refuses to budge. I've tried wd 40 type spray, but to no avail.
Have you come across this issue before? Can you give any advice, please? Thanks
Jeff Woods
Jeff Woods
Sep 12, 2021 at 6:00 AM
