Hood release
2003 HYUNDAI SANTA FE
158,233 MILES • V6 • AWD • AUTOMATIC
FETTIKID
Hood lever under steering wheel wont open hood no pressure on the lever.
Aug 14, 2016 at 1:50 AM
HMAC300
  • 48,601 POSTS
the cable may have broken, try pulling lever for hood and bang hood with palm of hand it may help it release, other wise you will have to try to get hood open without cable which can be time consuming. make sure to lube hood latch when open.
Aug 14, 2016 at 3:45 AM
FETTIKID
Cables not broke just stuck open and has no tension to pull itself back.
Aug 15, 2016 at 7:53 AM
HMAC300
  • 48,601 POSTS
lube the latch and check for a broken spring on that and lube cable if you can.
Aug 15, 2016 at 8:35 AM
